Control galvo in x-y directions
We are currently using a resonant-galvo scanner from Thorlabs (LSKGR-08) which is connected to NI PXie 6363 and NI PXie 1073. We are looking to control the scanner to move the mirror in the x and y directions. This is the code we have so far in which we are able to control the field size and alignment position.
Any suggestions or help is greatly appreciated, thank you!
(1,810 Views)
It is painful to look at your code.  What I see is lots of code that looks like this:  Not very helpful, I'm sure you'llUseless Code.png
agree.
  • Learn how to create sub-VIs and "bury the picky detail that we don't need to see while trying to understand the Big Picture in a sub-VI (give it a meaningful name, like "Current Field Size Position", or "Move to Field Size".
  • Use the Error Line "almost everywhere".  Try to never use the Frame Sequence (there are places it is useful, but an ordinary VI is usually not one of them.
  • You probably should be using something like the Queued Message Handler or a State Machine design, with the States being the "Things you want to do" or "the Decisions You Need to Make".
  • Put LabVIEW away and break out your Favorite Word Processor.  Write a one-page summary of what you what this program to do (don't worry about how it does it).  This might be "Get a set of parameters from the User describing where to start the Galvo", "Get a second set saying how to Move the Galvo, including how fast and where to", "Start the Movement", "Stop the Movement", maybe other things.
  • You should have an "army of sub-VIs" that do all of the Heavy Lifting.  Once you say "I want to go to 200, 340", you call "Move to X, Y" and give it a Cluster representing Where and maybe How Fast.  Just as you group "operations to do" into sub-VIs, you should think about organizing your Data into sensible "conglomerates" using Clusters (where you can assign "User-friendly" names like X, Y, X Velocity, Y Acceleration, etc.).
  • One (crude, but effective) way to get a sense of the quality of your code is to look at a typical VI or sub-VI.  Strive to get every Block Diagram to fit on a "typical Laptop Screen" (the Top Level VI of a Project I'm currently developing with a few hundred VIs and Controls is roughly 1000 x 700 pixels, and easily meets the "Labtop Screen" test), as do all the other VIs in this Project).
(1,749 Views)
