Control for strictly typed VI reference from calling VI - conversion
Hi team ,
My requirement was need to call one by one (10 to 15 ) different  testcases  dynamically from main VI program during each state execution from main vi . i used call by reference because i can control/ Change parameters . so only i choose call by reference method
i have attached a image . Please see for reference
In that image ,
Method 1 : I used a static reference for getting a VI path and VI server class i browsed and choose a particular VI and its connector pane was turned out as a strict reference type . I got the output successful in this method . But for 10 to 15 test cases i am planning for method 2
Method 2 :.  Here i like to put reference only.  10 to 15 test cases  are .there . so i cant create  vi for every test case as like method 1 .  Because i will plan to  call particular vi from main vi . there are so many states in main vi . During their each state execution , i just need to call particular VI ( sub VI ) server class type reference from main VI .
It was accepting only the strict type reference only in call by reference . How to convert . ?
i used type cast and  tried .  i like to Progress in method 2 only . Please see image for better understanding
please give suggestions for this
Thanks in advance
(1,650 Views)
For Method 2, use a strict VI reference constant, just like you did in Method 1.
(1,625 Views)
Seems like this would be easier to use Object Oriented with Dynamic Dispatch.  Then you can just use a simple Factory Pattern using Get LV Class Default Value.vi to load up the tests you need.  You could then possibly just use a FOR loop to iterate over the tests you created.
(1,614 Views)
