Incorrect constant size and value after multiple Undo/Redo operations
First of all, I understand this can be very old issue, but I didn't find any mention of it anywhere.
Environment:
Windows 8.1
LabVIEW 2018 SP1 f4
Steps to Reproduce:
  1. Place a constant on your BD;
  2. Change its value multiple times, completing the edit operation in between;
  3. Use Undo / Redo operation multiple times in a random order.
Expected Result:
Constant values change in the same order you've changed them. Constant size correspond to its value.
Actual Result:
Value order is messing up, some values get lost completely. Constant size is messing up.
[Edit:] Reported to NI with SR #7808322.
(2,845 Views)
NI Technical Support wrote:
I find that this bug is known for a long time.
At this moment development group is focused in high priority issues but I hope this bug will be fixed in the near future.
CAR number: 1065457.
Well, I guess this issue with fundamental functionality (probably 0-day) is not high priority...
OK, at least it will be reconsidered. (maybe)
(2,726 Views)
