β05-17-2016 03:38 AM
I have created a formula node, and one of the variables is connected to a DAQ assistant by means of a 'from DDT' which converts the dynamic data to the latest value. However, I want my formula node to continuously update the output if the input from the DAQ assistant changes. Right now it only takes the value from the moment I press 'run'. How do I get my formula node to do that?
β05-17-2016 03:46 AM
Put everything in a while loop and check if the last value is different from the new value. if true run your code in a case structure.
β10-29-2019 06:50 AM
Could you please share a photo of your code? I have the same issue..
