Continuously Updating Graph Help
Relatively new too labview. What I am looking to do is relatively simple. I have an accelerometer that I would like to aquire data from. I want to Log 5 seconds of data at 100hz. When I use a waveform graph it does not update until the entier loops have finished. I can get a live updating graph if i use a waveform chart, but the time scale is set to system time (HH:MM:SS). I simply want it to start at 0 seconds and go to 5 seconds. The data does not need to be logged on the graph as I will simply be outputting to a file.
Is there a way to get a continuously updating graph using a waveform graph or is there a way to set up a waveform chart with a time scale that starts at 0 and goes until a defined value (5 seconds)
(4,731 Views)
You must use a waveform chart. Not a graph. Goto help in the toolbar, then select Find Examples. Search for chart.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,719 Views)
