Context Help for Property Node of a Class
I want to have context help available for a property node of an lvclass.  Specifically, when the mouse hovers over this:
As it is now, I only get this:
I've put documentation into the VI that implements the write-property function:
But I can't figure out how to get it to show up for the property node.
(1,588 Views)
You should probably post it on the idea exchange, harvest enough traction and then wait for NI to implement it...
(1,454 Views)
It works for me, I tried all the way back to LabVIEW 2014, and in LabVIEW 2020. When I hover over the 'Error Debug' text in the property node, I get context help that matches the VI description of the accessor VI:
I don't know what could be different about your setup vs. mine that would cause it to not work for you.
(1,407 Views)
