03-07-2019 03:37 AM
i have issue with connecting labview with Rigol DS1054 osciloscope.
I have already installed NI-VISA 18.5, NI-SERIAL 18.5. Labview version is 16. Also rigol DS1000 driver has been instaled.
I get error message: Error -1073807346, VISA: (Hex 0xBFFF000E) The given session or object reference is invalid. In att.
It seams that labview and VISA doesn't see COM port's.
Has someone idea, how can i solved this issue?
Thank you for your support.
03-07-2019 03:44 AM
03-07-2019 03:54 AM
connection is over USB.
Sub-tree. i am not shure what is this, but check attachemnt if this is it...
in visa resources i have only refresh, not a single COM.
03-07-2019 04:09 AM - edited 03-07-2019 04:12 AM
Hi milan,
Because there is no COM port visible in your MAX screenshot.
Are there any in your (Windows) device manager?
When there is a COM port, then MAX shows it like this:
Why do think you need to use COM ports, when the scope connects over USB?
What does the manual of your scope say about this topic?
03-07-2019 04:43 AM
Hi Gerd,
i find what was the problem.
Osciloscope was not set correctly, for sending data over USB PictBridge.
Now i get visa resource and picture on my screen! 🙂
You can check results in att.
Thank you on your help and time!
Best regards.
