My initial reaction is that it would be possible, albeit possibly somewhat complicated, to do that. I am confused as to your set up, however. What FieldPoint module(s) do you have, or at least what is the controlling module? Since you posted the question in the LabVIEW Real-Time group, I am assuming your code is on the FP-2000 or FP-2010, running in the embedded LabVIEW environment. There are a couple of questions:
1. Where is the file that needs to be sent via FTP?
2. Where is the modem that will be connecting to the ISP?
If my assumption about the FP-20x0 was incorrect, then this question would be better handled by someone in our industrial automation group or someone else browsing the developer exchange. Either way, the answer to the above questions a
nd a bit of a clarification would help either myself or someone else provide you with assistance.
