Configuring Bidirectional Lines for the PXI-6251
Hi, I am wondering if anyone knows if the PXI-6251 can have it's DIOs configuered as bidirectional lines? If so, how is it done, and are there some examples? If not, what are alternatives? I have a sensor device that has a single control/output line.
Please help! Thanks so much!
(2,490 Views)
The lines of 6251 are bi-directional. Lines will configured as input/ouput depending on the task chosen. Inside LabVIEW, you can use DAQmx Digital Input Task to configure a line as digital input. you can use DAQmx Digital Output Task to configure a digital line as output line.
LabVIEW comes with some good examples. Please refer to the following examples
To configure a line as output:
C:\Program Files\National Instruments\LabVIEW 8.0\examples\DAQmx\Digital\Generate Values.llb\Write Dig Chan.vi.
To configure a line as input:
C:\Program Files\National Instruments\LabVIEW 8.2\examples\DAQmx\Digital\Read Values.llb\Read Dig Chan.vi
Can you please provide some more information about your application such as clocking information, are you trying to read/write information from/to a chip. Please try to post some more information on the sensor you are trying to communicate with.
Kalyanramu Vemishetty
Automated Test Systems Engineer
(2,476 Views)
