Configuration Control - Tortoise SVN
Can someone recommend configuration control software that can be integrated with Labview NGX?
I have tried tortoise SVN but can't get Labview NGX to recognise it.
(1,845 Views)
Hi TC,
I would rather recommend to get rid of NXG and use the "classic" LabVIEW versions
I have tried tortoise SVN…
What exactly do you want to control? Which "configurations" are you talking about?
SVN is a SCC tool: Source Code Control…
(1,840 Views)
Thanks for the quick response.
I have installed Tortoise SVN but when I try and select the 'Source Control Provider Name' within LabviewI can't select anything.
I just wondered if I was doing something wrong.
(1,796 Views)
No, your are not, tortoise SVN will not show up on that option dialog of LabVIEW.
cf. this KB: Software Configuration Management and LabVIEW - NI
Regards, Jens
Kudos are welcome...
(1,793 Views)
Viewpoint Systems has a neat little TSVN tool that is the next best thing.  Maybe even the first best thing.  Check it out.  You can get it through VIPM.
Bill
CLD
(Mid-Level minion.)
(1,782 Views)
