Concatenating Terminal Control Reference
@Darin.K wrote:
Treating scalar concatenation like indexing is probably the most intuitive, but I would argue that the most consistent treatment would be to treat it as 'last value'.  Indexing raises the dimensionality, concatenation keeps it the same so I would say scalar in gives scalar out.
There is one exception, and that is this one which baffles me:
I am tired of tossing U8 conversions or a concatenate strings function in there.  Strings are definitely the one scalar data type where there is no confusion about what 'concatenate' means....
Well that is one where I alwways use concatinate strings OUTSIDE the loop.  But having that inside the tunnel would be rich   The datatype is known and Concatinate Strings is a cheap primitive "post loop"" or "in tunnel"  should be equivallent.
"Should be" isn't "Is" -Jay
Message 11 of 16
(1,649 Views)
If you would stop thinking like a "real" programmer, this would not baffle you. Strings are magical scalers of undefined size that show up in memory as uniform text... not arrays of bytes that grow in memory as you add to them.
Message 12 of 16
(1,635 Views)
@Zwired1 wrote:
works for me...
I looked closer and see you changed the tunnel type to concatenating.
Is this option not available in LV 2010?
- Partha ( CLD until Oct 2027 🙂 )
Message 13 of 16
(1,618 Views)
Both the concat feature on tunnels and the conditional indexing option were added in 2012.
Greg, I think I'm having a flashback moment:
___________________
Try to take over the world!
Message 14 of 16
(1,610 Views)
Regardless of the way it's represented and handled, I agree with Darin that a concat option on a string is clear, especially when you consider that LV had concat for strings long before it had concat for arrays. That said, the lack of it doesn't bother me because a) I don't do this that often and b) the "concat the array of strings" option is simple enough so that it doesn't pass the annoyance threshold.
___________________
Message 15 of 16
(1,609 Views)
There is this old idea, of course.
A scalar string wired to a concatenating tunnel should result in a concatenated string, while wiring an array of strings should concatenate the array of strings instead.
Message 16 of 16
(1,586 Views)
