Concatenate array?
I have two arrays and I want to connect them into one. The problem is that I want to concatenate them ( meaning to add the columns of array 2 in to array 1 and not the lines in array 2 into array 1 like "Bulid array" does) - ( I have pressed the " concatenate array" in the options of " Build array" but still it doesn't work)
Does any one have an idea how to do this?
Expamle : array 1 ( {1 2 3}, {1 2 3}) array 2: ({4 5 6}, {4 5 6 }) -> result ({1 2 3 4 5 6}, {1 2 3 4 5 6}).
Message 1 of 9
(6,258 Views)
Just use built array with the concatenate option. BUT now place a FOR loop around the built array node. (I think this is what you want).
Message Edited by altenbach on 07-18-2005 12:19 AM
Message 2 of 9
(6,263 Views)
Hello Eran,
you can use this one too...
Message Edited by GerdW on 07-18-2005 09:23 AM
Message 3 of 9
(6,249 Views)
Thanky you very much Smiley Very Happy
Message 4 of 9
(6,241 Views)
Message 5 of 9
(6,229 Views)
How can we concatenate two different size of arrays?
Array1 ( {1 2 3}, {1 2 3}) Array 2: ({4 5 }, {4 5 }) -> result ({1 2 3 4 5 }, {1 2 3 4 5 }).
Message 6 of 9
(5,707 Views)
same code (try it).  Different number of rows would be different (and ill-defined).
Message 7 of 9
(5,694 Views)
Ben
Message 8 of 9
(5,693 Views)
Thanks.
I got problem because I forgot to check on concatenate input.
Message 9 of 9
(5,684 Views)
