Concatenate Strings with several Colors
Hello all,
I'm currently in work placement and I must treat a climb of information radio units in the form of script.
I wish "filter" these information by color code according to their origin etc...
I created a simple VI permitting to concatenate strings choising its color.
The treatment time become very long (about many tenth second) when the string is composed by some lines with different colors.
In my application, the scripts can be very long, and become a problem...
Could-you, please, help me with a treatment time faster?
I use Labview 8.5, attached my exemple.
Thanks!
Julien
Message 1 of 8
(3,226 Views)
Hi Julien,
see this thread and GerdW´s post. I think this should be a good solution for you:
http://forums.ni.com/ni/board/message?board.id=170&message.id=302349&query.id=43475#M302349.
Mike
Message Edited by MikeS81 on 04-21-2008 02:51 PM
Message 2 of 8
(3,211 Views)
Hi Mike,
Thank you for your answer, but I already saw that post and theses solutions don't suit to my application. All Lines must be visible anytime.
Is it possible to concatenate text with different color without to redefine all strings ??
Julien
Message 3 of 8
(3,194 Views)
TeamJP34 wrote:
...to concatenate text with different color without to redefine all strings ??
Julien
Hi Julien,
i think this is not possible. If all lines has to be visible at any time, why did you use a scroll bar?? Smiley Wink
Mike
Message Edited by MikeS81 on 04-21-2008 03:21 PM
Message 4 of 8
(3,192 Views)
In my example the scroll bar are enabled, I said that because I must not to cut the script with some lines to optimize the treatment time...
Julien
Message 5 of 8
(3,181 Views)
Try attached version which uses the Defer Panel Update property.
Message 6 of 8
(3,173 Views)
Thanks JB for your answer.
That is perfect ! 🙂
Julien
Message 7 of 8
(3,165 Views)
One of LabVIEW's underused property !
Message 8 of 8
(3,155 Views)
