Concatenate 2d arrays
cute, except for the ugly coercion dot. 😉
(Wasn't even aware that "build matrix" has a right-click option for the mode. I wonder why the default behavior is opposite to the build array mode...)
Message 11 of 15
(2,637 Views)
You can always use the VI to do the Matrix to Array conversion.  It literally does nothing except hide the coercion dot inside the subVI.
Message 12 of 15
(2,632 Views)
The solution is however less universal, because it will not work for e.g. 2D boolean arrays and such. 😞
Message 13 of 15
(2,628 Views)
@Darin.K wrote:
Some people might try to suggest that you can do more with less code.....
I've always done the transpose build shuffle.  Good to know that for numeric arrays there is another option.
Message 14 of 15
(2,607 Views)
Thanks for all contributions! Great help!
Message 15 of 15
(2,593 Views)
