Comunications port Gps-Pocket pc
I am working with a Pocket PC 2003. I must connect the GPS to the Pocket pc and I have some problems.
Does anyone have a program that reads from a gps, processes the signal and extracts the nmea sentence?
Another question is: Does Pocket pc read from a gps connected to Com 7 or another COM?
Thank you!!!!!!!!!!!!!!!!!!!!!!!
Greta
(2,812 Views)
What NMEA sentence(s) are you trying to extract?  See if this discussion helps: http://forums.ni.com/ni/board/message?board.id=170&message.id=149026#M149026
(2,810 Views)
Hello Brian Beal.
I want to extract the sentence $GPGGA.
I do not know with which port COM the Pocket pc communicates with the GPS!??
I have made a program that works with PC, and it communicates through the ports COM 1-4. But the problem is that with the Pocket pc not works, it doesn't allow to execute it.
Thanks.
Greta
(2,805 Views)
Sorry, but I don't know anything about PocketPC's.  I can help with the GPS side, though.  See if this discussion helps: http://forums.ni.com/ni/board/message?board.id=170&message.id=123951&requireLogin=False
(2,798 Views)
Thank you very much Brian Beal.  Smiley Happy
G
(2,775 Views)
