Complex Animations
Im looking at wanting to make a simple program that allows me to simulate a crossrads and a pedestrian crossing to use as an example of a state machine.
I wonder if there are any good tutorials or methods of getting animations to show cars travelling up and down the road?
I understand that i can do this sort of animation with a number of .gif files but is there a more elegant way of doing this?
Cheers
Mark  (LabView Noobie)
(4,391 Views)
For getting animations to show cars travelling up and down the road, that you can customize "Slide" control, the scale trave is the load, and the block is the car, the car can be a GIF image, its wheels are moving. then you would get the car up and down goal.
________________________________________________________
Try to make everything Automatic
(4,382 Views)
Hi thanks for the reply,
I will have a look at this later and get back to you with any problems I encounter.
Mark
(4,374 Views)
Hi
Have you looked at:
NI Example Finder -> Building user interfaces -> Customizing controls
Using custom controls.vi
/gunnar
Edster wrote:
> Hi,
> Cheers
(4,363 Views)
The only tool available for real animation is the picture control. Some example can be found here.
Other than that you can do trick animations like the mentioned changing value of a slide, using a picture ring or moving a control around using its properties.
___________________
Try to take over the world!
(4,353 Views)
Yes, tst's recommendation is so good, and the link exercise is so cool, I give you five stars Smiley Wink
(4,332 Views)
