Compiled Data Switched instantly from front panel?
This is really only for looks, but I was wondering if there was a way to collect data and convert into two different types instantly on the front panel. Let's use binary and hexadecimal because that's what I am collecting. I have a huge array of numbers that gets converted into a huge array of binary or hexadecimal, depending on what the user chooses from the front panel. If that person chose binary, but then wants to look at it in hex, could this be done without re-running the VI?
Message 1 of 11
(3,574 Views)
Accepted by Szklanam
Just right-click the indicator Visable Items>> Check Radix
The operator can select Decimal, Octal, Hexadecimal or Binary
"Should be" isn't "Is" -Jay
Message 2 of 11
(3,570 Views)
Jeff's solution is really simple and you should be showing the Radix anyways for clearity if you are showing a numeric in anything but decimal.  Nothing like thinking you have a bug when you really don't because you thought you read decimal and it was really hex.
The other option I've seen is to have a control to allow the user to choose the radix for all of the controls and you can then set the display using property nodes.
Message 3 of 11
(3,564 Views)
I am only able to choose decimal or SI notation
Message 4 of 11
(3,563 Views)
That's because your data type is a floating point.  You have to have an integer type (U8, I8, U16, etc.) to be able to display hex, binary, or octal (who the heck uses octal anymore?).
Message 5 of 11
(3,558 Views)
Ohhhh okay that makes sense. I also found out that since I have a case statement with my array that way the user could choose binary or hex, my default is binary and when I right click on that array's properties, the display style has normal, \code, password, and hex, so this will work for me since I can just use normal or hex. Thank you very much for the help. I appreciate it.
Message 6 of 11
(3,549 Views)
@Szklanam wrote:
...when I right click on that array's properties, the display style has normal, \code, password, and hex, so this will work for me since I can just use normal or hex.
Ah, so you are using a string.  You can still use the same trick for those now.
Message 7 of 11
(3,545 Views)
I fooled around a little bit and it was much cleaner using an integer and applying radix to the indicator instead of the "Number to Hex" and the "Format Value" for the hex and binary conversions respectively Smiley Happy
Message 8 of 11
(3,543 Views)
I'm curious.  When was octal ever really used?  Were there particular situations where it made sense to use it?
Message 9 of 11
(3,535 Views)
Wayback mode. Assembly had 2^3 instructions made sense then
Message 10 of 11
(3,527 Views)
