Comparing elements of array with previous ones and insert index of elements where v[i+1]<v[i] in another array
Hi ptavernise,
I cannot understand where is the error.
Well, LabVIEW shows you exactly where the error is located. It even describes the error in the context help when you move the mouse to the location…
Problems I see in your VI:
- you want to compare with several elements, but in your shift register you only read one value from previous iteration…
- you want to compare several elements, but you compare with the whole waveform at once…
- again (as has been said before) you store the index in the shift register and use this index to compare with values of elements…
Please learn the LabVIEW basics like autoindexing and using shift registers…
Message 11 of 17
(1,426 Views)
sorry,
but i'm not able to find solutions, can you show me how to do please?
Message 12 of 17
(1,418 Views)
Accepted by ptavernise2345
Hi ptavernise,
your really should start to learn LabVIEW. And drawing an algorithm on a sheet of paper first might help too…
Spoiler
This works according to your description:
check.pngIt's not perfect (aka free of errors). try to understand it by reading the help for all functions!
Message 13 of 17
(1,402 Views)
The block with 5 where is located(queue)?
Message 14 of 17
(1,394 Views)
As i pointed earlier start reading basics, then you will get most of the things.
-The VI which you asked for: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/ptbypt/other-functions-llb/data-que...
uday
Message 15 of 17
(1,381 Views)
as i stated previously i'm new to labview. Now i need to create a VI which receiving an array determins the indexes of prime numbers and insert these indexes in another array and if number is not prime insert 0 in array output.
Example
Array input=[1,2,25,3,7,5,7,36]
Array output=[0,1,0,3,4,5,6,0]
Any help would be kindly appreciated
Thank you so much
Message 16 of 17
(1,383 Views)
Hi ptavernise,
now it starts to get silly!
You started a new thread for the very same algorithm?
All that has changed is the condition you want to check!
(And well: there is a PrimeFactors function in LabVIEW available…)
Message 17 of 17
(1,369 Views)
