Comparing array elements value In labview
I feel really dumb but what is negate option ? i cant find a tutorial that can help with this case
Message 11 of 16
(2,933 Views)
It's one of the small yellow triangle nodes. It outputs the negative of whatever you wire into it. I belive you can find it on the Numeric palette.
The symbol looks like "-x"
GCentralI'm attending the GLA Summit!
Message 12 of 16
(2,929 Views)
Unfortunately didn't solve my problem. it still compares the third element with first. instead of comparing second to 1st, 3rd to 2nd, 4th to 3rd..
Message 13 of 16
(2,911 Views)
I'm pretty sure it doesn't.
What output did you want? (I used a slightly longer input here)
Message 14 of 16
(2,903 Views)
in your example if i wanna run the pattern twice how can i make it ? so in your example once it hit 4 , next number is again 5. so it would be 5-4=1 but instead of 1 it shows 5. I followed your pattern and once it hit the last one restarts from the beginning
Message 15 of 16
(2,883 Views)
Accepted by Canucks.canucks
If I understand what you're asking correctly, you can remove the "0" value outside of the loop wired to the Shift Register.
I'm not certain that's really what you want, but it'll do what you ask.
An alternative might be to index the array before starting, take the 0th element, and add it to the end (if you just want one element added) or if you want a fixed number of repeats, to nest For loops.
Message 16 of 16
(2,878 Views)
