Compare voltage
Hello.
I've created a VI to compare measure. I begin with a simple button.
I want to replace the button with data collected on a myDAQ. But reading data on myDAQ sent flow of data, and I need to only one value ? How extract une value from the flow ?
Pascal
(4,140 Views)
When you configure your DAQ assistant, you need to set the assistant to 1 Sample (On Demand) in the configuration panel as shown in the screen shot
Rodéric L
Certified LabVIEW Architect
(4,120 Views)
Hello
It's already so...
Pascal
(4,114 Views)
A precision :
Pasal
(4,109 Views)
Accepted by pascal_gagnebin
Hi Pascal, see the attached VI (older version, but should open).
Place your daq assistant as indicated and see the results.
Hope this is what you are looking for.
Regards, W
P.S. I could not resist to show an alternative for your case structure Smiley Wink
(4,105 Views)
Nice !
Thank's a lot!
Smiley Happy
(4,086 Views)
