Compare set values 1D-Array
I have checked but I can't find spaces but I noticed that the first string corresponding to the number 1 is not read.
Message 11 of 14
(673 Views)
Accepted by frank22
Because you posted the actual VI, I could see the problem was with the case that was not visible in your picture.
In your other case you gave it a value of 1.  It should be -1.
The first case could be just Default rather than "0, Default".
If you do a less than zero comparison, you can turn that case structure into True and False since it will be a Boolean value coming out of the comparison.
Message 12 of 14
(655 Views)
I had made that mistake. Now it works well. Thanks for everything
Message 13 of 14
(634 Views)
Of course if the arrays are very big, the current solution becomes very inefficient.
Better solutions could be implemented by e.g. sorting the two input arrays and adjusting the search start index as you go along. Of course variant attributes come to mind too (and if you would upgrade to LabVIEW 2019, a solution based on a "set" would work great ;))
Message 14 of 14
(618 Views)
