Compare element in two 1D arrays and store in another 1D array
RightClick on Tunnel Mode and Select Concatenating.
Message 11 of 13
(1,119 Views)
You are connecting an array of booleans to the conditional tunnel which is probably why it's broken. You will need to make sure every element in that array is true to make sure you want to pass the array.
Message 12 of 13
(1,111 Views)
As a recommendation, instead of passing the array out of the loop, you can wire the integer value from before the while loop to the output tunnel to you won't have to reconstruct the integers afterwords.
Message 13 of 13
(1,109 Views)
