Companding
Please help me answer this question will be greatly appreciated, what is the function in the loop?
(4,013 Views)
Let's call the indexed input X[i]
For each loop iteration:
If X[i] is <= inverse(A) then result = X[i]*A
else,
result = ln (X[i]*A)+1
Is this what you wanted to know?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,003 Views)
mahady,
The function in the loop is Natural Logarithm.  You can find out the name and description of any LabVIEW function by bringing up Context Help (ctrl-H) and moving your mouse over the function.  You can then click "Detailed Help" to see more information about the function.
Chris M
(3,991 Views)
Ahh beautifully explained, I see ur using array indexing here, but briefly could u explain how u came up with inverse(A)? Are u familiar with the a law compression?
(3,976 Views)
