Communication with vector Hardware VN 5640 via ethernet using vxlapi.dll
I want to communicate with VN 5640 Hardware directly using vxlapi.dll, sending the Ethernet signal to VN 5640 using LabVIEW using dll method please share any knowledge article which I can use as reference.
(929 Views)
Vector XL Driver - LabVIEW wrappers
Might not have support for Ethernet, but it is a good starting point.
https://tmesystems.net/
(910 Views)
I am also looking for same, I have tried it for CAN ,LIN.  i was able to do, but couldn't succeeded for Ethernet It will be a great help if someone can provide some solution ..
(896 Views)
