Communication between PC and PLC
What is an easy way to build a bidirectional communication between a PC and a PLC (Siemens S7), if possible using Ethernet and TCP/IP. Where can I find descriptions ?
(4,142 Views)
_______________________________________________
LabVIEW Datalogging & Supervisory Control (DSC), which is an add-on module for LabVIEW provides a lot of functionality to establish communications between PLCs/controllers and the PC. In addition to supporting OPC, it comes with a suite of drivers for third-party PLCs:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/49524fe0fbb7954686256aab0057bb70?OpenDocument#2
As you will see in the list, there are some drivers for the Siemens series of PLCs. However, you may require additional hardware like plug-in card or adapters.
You will find good information on this area if you search on ni.com/zone for keywords like PLC. Here are a few entries:
Siemens S7 PLC with HMI Adapter - Tutorial:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/cc021cd15890283286256a33006eba74?OpenDocument
Where can I Find Drivers for Communicating to PLCs, RTUs, and Other Industrial Hardware?
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/13ee0a9e2c43f0db86256a6100722651?OpenDocument
Hope this helps.
Khalid 🙂
(4,143 Views)
