Hi Wolfram2,
Objects and database parameters can generate alarms in the Lookout OPC Server. At this time, however, you cannot access these alarms through LabVIEW DSC or any other client software. This is due to the fact that Lookout (as well as Lookout Protocol Drivers) does not expose the $Alarm object through the OPC Server.
Chad Pelletier
