Communicating with a Brother QL-570 Label Printer via USB
I have written a program that needs to send a serial number to a Brother QL-570 Label Printer.  The printer uses USB, and the Measurement & Automation Explorer does not see USB devices as it does comm ports etc.
Using the report VI's, I have only succeeded in causing the printer to line feed.  No data is printed.
I believe I could succeed using property nodes, but I don't know how to create the reference to the printer.
Can anyone help.
Note:  Both word and Excel see the USB printer but LabView does not.
Pmel111
(6,573 Views)
You may want to read over this thread. Smiley Wink
(6,562 Views)
Hi Pmel
I met the same problem in controling QL-570 by Labview, could you tell me how to do it?
(5,665 Views)
He last visited 5 years ago.  Did you check out the link provided in the last post of 2008?
Bill
CLD
(Mid-Level minion.)
(5,651 Views)
after I removed the 64-bit b-PAC SDK and then installed a 32-bit, it works.
(5,604 Views)
