キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Communicating by TCP/IP with ESP32 as client and PC with LabVIEW as Server/Listener
解決済み
解決策を見る
Hello, everyone. I'll get straight to the point: for the past 2 days I'm trying, without success, to connect my ESP32 to my router and send data through TCP/IP to my PC which runs LabVIEW with a TCP/IP Listener. What bothers me the most is that when the ESP32 acts as a server my PC can connect to it and send data from LabVIEW with a simple TCP/IP connection VI. But vice-versa the listener doesn't even accept the client. And if I try to send/receive data between 2 VIs (one as a listener, one as a client), it works without a problem. I'll attach here the 2 .ino files (client and server respectively) and the 2 .vi files (send and receive data to/from ESP). If you want to test these make sure to correctly insert your correct ssid, password and IP host of the PC which runs LabVIEW. Thank you in advance!
0 件の賞賛
メッセージ1/9
12,199件の閲覧回数
I'd first check my IP range. It's usually a lot easier if both devices are in the same range.
I'd turn my firewall off. Temporarily, of course.
I'd start with a simple connection. E.g. no passwords etc.. If possible.
Does the ESP give an error code?
Checking with 2 VIs on the same computer isn't really a test. Can you test on 2 PCs?
メッセージ2/9
12,151件の閲覧回数
I turned off my firewall and now it looks like the ESP successfully sends data to labview 😄
but how can I keep myself safe, tho? What should I disable from firewall and keep the communication going at the same time?
0 件の賞賛
メッセージ3/9
12,132件の閲覧回数
解決策
トピック作成者RimaDeltaが受理
You will have to add an exception to the firewall. The trick is to find what exception to add, and to which application.
I think the exception should be added to LabVIEW.exe. Of course, also to your exe if\when you build one.
The firewall is probably blocking incoming TCP\IP connections. But without being able to test, I'm not too confident to advice on details.
Details also depend on the firewall you're using.
0 件の賞賛
メッセージ4/9
12,127件の閲覧回数
Once I figure out I'll respond here. Thank you a lot for your time and help!
メッセージ5/9
12,119件の閲覧回数
Alright, I enabled firewall both for private and public domains and ONLY added exceptions/allowed (private and public) for all LabVIEW iterations that appear in the firewall apps list. I hope this will help all those who encounter the same problem I did.
0 件の賞賛
メッセージ6/9
12,112件の閲覧回数
Hai Rimadelta ,
I am gobi , now i am using esp32 programmer module , I need to communicate ESP32 with LabVIEW . Could you please tell me producer to communicate , I need to program esp32 module through the LabVIEW . Could you please guide me ?
0 件の賞賛
メッセージ7/9
11,004件の閲覧回数
@Gobi1230 wrote:
Hai Rimadelta ,
Programming an esp32 is a completely different topic (this one is about communicating with a ESP32)...
Start a new topic.
0 件の賞賛
メッセージ8/9
10,999件の閲覧回数
Anyone please can send a file in Labview 17..
0 件の賞賛
メッセージ9/9
6,932件の閲覧回数
