Communicating LabVIEW with a Zebra Printer
Hi
I need help to print something using Zebra T402 printer. Anyone knows how to do it or if you guys have any useful links that I could refer to? If there are any drivers available, that would also help. I tried to search everywhere but still couldn't do it. Previously i was using IDAutomation Barcode Label Software to do the printing but I'm thinking of automating it using LabVIEW.
Thanks in advance!
(2,359 Views)
Google lists posts, including ones to this LabVIEW Forum, that seem to have worked for others.  You can also try the search engine on the first page of this LabVIEW Forum.
(2,352 Views)
Accepted by HarithJasri
This printer supports ZPL, a text-based protocol for zebra printers. The documentation is quite good, so I'd start with that.
You can send commands to just start a new label, add texts, barcodes, lines and more, and then print that label. You can also create a template, where your program only has to provide data for some placeholder fields. (For sure, there are tools for that.)
However, I wanted the label to be printed to be shown on screen. So I generate a LV picture, and send this to print it:
^XA
^FOx,yEncodedGraphic
^XZ
XA starts a new label, XZ prints the label. FO is the offset (in pixels) for the following object, which in my case is an ASCII encoded picture, generated by the code below. Even that is easy: Encode the picture row by row. Eight pixels form a byte, with MSB first. Therefore, you need to add some bits if the image width is not a multiple of 8.
(2,310 Views)
Hi, Sebastian
Thanks for the reply. I'll try to do per your suggestion. Also, where cold I get the documentation? Is it in the Zebra website?
Also, Bob
Thanks for the suggestion.
(2,267 Views)
@HarithJasri wrote:
Hi, Sebastian
Yes you can find some information there, but i find this site to be quite helpful.
Labelary Online ZPL Viewer
Qestit Systems
Certified-LabVIEW-Developer
(2,244 Views)
Holy moly! this is nice!
Thanks, Yamaeda!
(2,242 Views)
