04-21-2008 05:25 AM
Hi, excuse the long post but I am evaluating the TPC-2012 as we are thinking of replacing our current (non-NI) touch panel with this unit. From our point of view there are several good reasons for doing this mainly as the rest of our system also run LabVIEW and integration will be much simpler using the TPC.
During the past week I’ve put the TPC through many tests evaluating the reliability, ease of use and ease of programming, data throughput, TCPIP packet handling and GUI abilities. Overall it seems to be a good product but I have the following issues which might be because of my inexperience with it, because of a bug or it might be a future feature – if anybody could comment on these it will help me a lot.
*** User input:
1) There seems to be no way to bring up an alpha-numeric keypad (CE native or user-created) when the user clicks inside a string or numeric control. The only events that are caught on these controls are ‘Key Down’ and ‘Value Change’ but neither triggers when the control receives the focus. I suppose one could place a transparent button on top of the control and catch its ‘value change’ or have a ‘Change Value’ button next to the control, but neither is a very elegant solution.
2) It is not possible to pop up a subVI’s front panel as a floating window, it has to fill the whole screen (as a dialog).
3) Boolean buttons (I’ve only seen this on pop-up dialog windows) do not work correctly if the mechanical action is ‘switch when released’ or ‘latch when released’. Even though the front panel shows the button is pressed, the diagram does not react to it and continues to use the old value. After several presses it works.
4) Most finger-on-screen events are missed on dialog windows. The first press always works (ie button turns dark), but subsequent presses only have a 1-in-10 chance of being picked up.
5) An enum control’s value can only be changed using the up-down buttons, if you want to select from a list rather use the combo box.
*** Data display
1) Graphs only supports lines. Scatter plots are not possible neither are bar-graphs.
2) The circular white background on a gauge is not centred around the needle or numbers. It is slightly offset to the top-left.
3) When an X-Y graph is updated it displays as it draws the lines. It would be better if it created the image in the background and then put it on the front panel once completed. This is particularly annoying when there are many datapoints to plot.
*** Other
1) The ‘TCPIP listen’ vi loads the processor a lot. It is significantly more efficient to use the ‘Create Listener’ with the ‘Wait on Listener’ functions (other application loops run 5 times faster).
2) Even though I added the exe to the list of applications to run at startup (using the ‘National Instruments Configurator’), it did not start after a reboot. Double-clicking on the exe in the same location starts it, and adding another exe (e.g. control panel) starts that exe after a reboot.
By the way
I’m using 8.5.1.
04-22-2008 06:05 AM
04-22-2008 08:11 AM
Your observations are valid. We recently invested in a number of TPC-2012's as HMI for our setup. I had originally thought that the process of creating interfaces would be easy (being LabVIEW), but I guess I didn't research it as well as I should have. I have repeatedly come across unsupported properties, idiosyncracies, and bugs which have required me to rewrite/rework my code. One example: I had a network-published shared variable of "custom" type that included a enum as part of a cluster. This works fine for "regular" LabVIEW, but causes the TPC application to crash/hang. It took a lot of troubleshooting to discover that it was necessary to split the enum out of the shared variable, into its own shared variable. Another problem I've had, for which I have a support call into NI right now, is that I can't get ANY of the graphs support "real" time on the x-axis. The waveform chart control updates incorrectly, adding 2-3 data points (presumably one for each component of the waveform?) on for each update cycle. The XY graph doesn't support time along the x-axis when deployed, despite the fact that the VI looks OK on the development computer. The waveform graph defaults to "Ignore waveform timestamp", and if you change the checkbox value, the x-axis changes scale to show time, but won't reflect the data. (However, the data exists, since the cursors are able to report them). The waveform graph example that is provided can be used to demonstrate that this doesn't work properly.
In summary, I find the TPC-2012 frustrating. We invested in LabVIEW since it would eliminate the need to focus on "how" to do, and allow me to focus on "what" to do. As a novice LabVIEW user, my experience has been extraordinary - the RT controller works fantastic and I've created some great interfaces for standard XP computers. However, lately, much of my effort has been devoted to finding work-arounds for the idiosyncracies of Windows CE and Touchpanel module. Hardware-wise, the TPC-2012 is fine.
Does NI offer the TPC-2012 with either XP or XPe OS's? The documentation seems to indicate that the TPC-2012 supports either of these operating systems, but I've found nothing else regarding any performance hit that would occur if either were installed (nor am I quite sure how to install the OS to the flash-drive - from the quick read I've had it seems either the flash drive OR a CD-rom can be connected, but not both). I would be very interested in knowing more about XP or XPe on these units, as it would allow the installation/use of a "regular" LabVIEW EXE, which would eliminate the need for working with the touch-panel module and provide the full gamut of properties/controls/programming capability. Since the TPC comes with drivers on the CD, the user would still be able to interface via "touch", making the difference transparent to them.
04-22-2008 08:54 AM
04-23-2008 09:21 AM
04-23-2008 11:35 PM
05-28-2008 02:47 PM
05-29-2008 06:00 AM
07-14-2008 03:09 AM
07-15-2008 01:34 PM
Hey Stijn,
When you mean that the numerical controls and string controls don't update when entered with a keyboard, are you referring to the onscreen touch keyboard that Windows CE has or are you connecting a keyboard via USB? Also, you are seeing both of those bugs only when you have two or more loops? What kind of loops are they? Just a standard while loop or does it work for a while loop or a for loop? Thanks.
