Combobox data question
Excuse me, Can you explain me, Why my Cronometer doesn't work while I'm doing it? It works before to do this thing about Event Case, but now It doesn't work 😕 But Comobox part work really well 😄
Message 11 of 22
(2,473 Views)
What is cronometer?
Message 12 of 22
(2,465 Views)
Elapsed Time, this part "Minutos muestreados" doesn't work 😕 and I don't know why.
Message 13 of 22
(2,462 Views)
You have an event structure.  It only executes when you have an event, in this case the value change on the one button.
If you need to keep a running track of elapsed time, create a second timeout event.  That will execute periodically whenever no other events occur.
Message 14 of 22
(2,459 Views)
Yes, I got it, but I need to have all the program inside Event case or not? I don't unerstand what I have to put inside Event case in my program.
Message 15 of 22
(2,428 Views)
Because you don't want to have the button be true for multiple loop iterations (like it could have been in your original code) and have it register 2 or 3 times when you only pressed once.
You've now seen how you can do it.  Figure out how to make it work better for you.  You situation sounded to me (and to others) that it needed an event structure.  There are other ways to do things, and maybe one of those don't need an event structure.  Try to figure out other methods for yourself.
Message 16 of 22
(2,408 Views)
I'll try it 😄 Thanks for help 🙂
Message 17 of 22
(2,404 Views)
Hi 🙂 excuse me, Can you teach me how to activate this Elapsed Time with a pulse? Not keeping push the button how I'm doing it. Please 🙂
Message 18 of 22
(2,346 Views)
Don't use Switch until released.
Message 19 of 22
(2,343 Views)
Yes, but I want to reset it with a switch, Can I do it?
I want to start the Elapsed time with the switch.
Message 20 of 22
(2,340 Views)
