Combining graphs
Is it possible to combine two graphs into one or to have a single graph that can graph data from two sources in different colors but in the same graph window so that there values can be compared on the fly?
Ty
Message 1 of 10
(5,636 Views)
Of course. If your data to the graph is a 1D array, you can just use the Build Array to create a 2D array that gets wired to the graph. The plot legend allows you to change the color of any plot that you choose. You can also do it programitically with property nodes. For basic information, look at the shipping example called Wavefrom Graph.
Message 2 of 10
(5,630 Views)
i am also trying to put my graphs together using looping. but they seem to come out from the same frequency range insted of what i am asking for. is there anything that i can set my frequency range other than a bundle?
thanks
Message 3 of 10
(5,551 Views)
Could you please be a bit more clearer??
Or probably attach a vi or snap shot of block diagram, to illustrate what you are doing
Message 4 of 10
(5,531 Views)
i have attached the vi. the only problem i have now is that the concatenating of the graph. the frequecy range appears to be at the same 400 points instead of what i intended. and the graphs A and B actually comes out as one colour.
Message 5 of 10
(5,528 Views)
Look at the modified version of you vi.
Collect the acquired data points (from each iteration of your 'for' loop) into shift register and plot it as shown
And, are you trying to convert the 2D array to a waveform plot by bundling the timing information??
Is this why you are using bundle function and passing the 'start/centre' and 'sweep frequency' values to it as 'x0' and 'del x' values respectively??
Message 6 of 10
(5,520 Views)
sorry but i am not able to open that vi that you uploaded. do you mind if you post it again?
Message 7 of 10
(5,518 Views)
Which version of LabVIEW are you using??
I have tried to save if for LabVIEW 7.1 and attached it along with this post.
Let me know if this works
If not, find attached a pic of the vi with modifications in 'False' case.
Just incorporate them in both the cases
Message 8 of 10
(5,512 Views)
thanks alot. the graph is able to load already. but can i ask why is it that when i run from 1000-1800 for frequency, it will come out 1801 fromt he graph?
Message 9 of 10
(5,506 Views)
The X scale max value is not a right measure of number of samples acquired.
To find out if the of samples acquired per sec = the sampling rate specified, Use an 'array size' function on acquired data ( ps: ensure that data is in array format)
Message Edited by devchander on 06-01-2007 12:13 AM
Message 10 of 10
(5,480 Views)
