‎11-11-2021 10:28 AM
When I used PuTTY, I was able to output numbers like in the serial monitor of the arduino IDE.
‎11-11-2021 10:58 AM
Thanks a lot. Now I'm even more stumped. 😄
‎07-20-2023 01:36 PM
I also have a similar problem with a com port that was working yesterday, but today its not showing up in NI Max. It is on my device manager, and I can Tera Term into it and communicate with it normally. Any suggestions on what to do next? Simple PC restart didn't help.
‎07-20-2023 02:45 PM
Detecting the available serial ports is tricky. NI-VISA uses a different approach than my serial port library. Both (NI-VISA and lvserial) are not detecting all serial ports, but I feel that the enumation of the registry works slightly better than NI-VISA.
Anyway, opening and using a serial port is a totally diffent thing. Have you tried to open the serial port (the COM4 ?). If there is no explicit check against "found serial ports" in NI-VISA, this should work without hassle.
