Com Port not showing up in LabVIEW
When I used PuTTY, I was able to output numbers like in the serial monitor of the arduino IDE.
Message 11 of 14
(1,672 Views)
Thanks a lot.  Now I'm even more stumped.  😄
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(1,667 Views)
I also have a similar problem with a com port that was working yesterday, but today its not showing up in NI Max. It is on my device manager, and I can Tera Term into it and communicate with it normally.  Any suggestions on what to do next?  Simple PC restart didn't help.
Message 13 of 14
(1,453 Views)
Detecting the available serial ports is tricky. NI-VISA uses a different approach than my serial port library. Both (NI-VISA and lvserial) are not detecting all serial ports, but I feel that the enumation of the registry works slightly better than NI-VISA.
Anyway, opening and using a serial port is a totally diffent thing. Have you tried to open the serial port (the COM4 ?). If there is no explicit check against "found serial ports" in NI-VISA, this should work without hassle.
Message 14 of 14
(1,433 Views)
