Color inspection Labview code
I saw a color inspection example in Ni website. Refer to image attached.
Anybody know where I can get it’s Labview code ?
Thank you
best regards.
Message 1 of 10
(3,341 Views)
IMG_0546
Color Matching - NI
Color Pattern Matching - NI
From IMAQ Match Color Pattern VI - LabView NI Vision Documentation:
Refer to the following for examples that use this VI.
  • LabVIEW\examples\Vision\2. Functions\Color Pattern Matching\Color Pattern Matching Example.llb
  • LabVIEW\examples\Vision\3. Applications\Fusebox Inspection Example.llb
  • LabVIEW\examples\Vision\3. Applications\Blister Pack Inspection Example.llb
You do need to install NI IMAQ...
Message 2 of 10
(3,325 Views)
Hi, Weibe
Thank you for your information.
I can't found the "tile identification" example code (what i mean is Tile Identification project file ) in NI example library.
Based on the "tile identification" example , there is a result score so i believed "tile identification" got his code .
Please correct me if i am wrong .
best regards.
Message 3 of 10
(3,294 Views)
Do you have any idea what year your example comes from?  The LabVIEW "Example Suite" has changed over the years.  In LabVIEW 2019 and later, there are only "Color Matching" and "Color Pattern Matching" in the Examples that are added when you have LabVIEW Vision Development Module installed.
Message 4 of 10
(3,278 Views)
Based on the document date  is 1May2023.
Message 5 of 10
(3,204 Views)
Hi, Weibe
I try to get Fusebox Inspection Example but can't get it.
Is it because of my labview install version is different ?
For your information, installed Labview 2022 Q3 community edition.
Can you please attached Fusebox Inspection Example in .vi  format for me.
So sorry to trouble you.
Thank you very much.
Message 6 of 10
(3,186 Views)
@Jeffrey_Oon wrote:
Hi, Weibe
I don't have it.
But if I did, it's wouldn't be mine to give.
The folder structure might have changed. If you didn't already, try opening Find Examples... from LabVIEW, and filter on keywords. Of course searching the examples folder in windows explorer might find it too (again, if you didn't already). If it's still there...
Message 7 of 10
(3,160 Views)
That help link reference to a old version of the Vision Development Module, VDM.
The help is from 2008.
These examples is no longer present on the current VDM.
I don't think you can find the example that you what, and if you could, you will still need to have VDM installed.
And VDM is not for LabVIEW Community Edition.
Message 8 of 10
(3,149 Views)
hi, wiebe,
The above example is belong to Labview which version (what year ) ?
thank you.
Message 9 of 10
(3,128 Views)
@Jeffrey_Oon wrote:
hi, wiebe,
thank you.
I don't know, but:
Message 10 of 10
(3,119 Views)
