取消
显示结果
搜索替代
您的意思是:
Color indicator
已解决!
转到解答
Hello Good Evening,
Is there any color indicator that can display color according to values
like example,
if value<10:
     displays "Green Color"
else if 10<value<20:
     displays "Yellow Color"
else value>20:
     displays "Red Color"
is there any indicator which can help me with this in labview if there is it would be very helpful
Thankyou
0 项奖励
1 条消息(共 6 条)
3,198 次查看
解答
已被主题作者 LarryDante 接受
Hi Larry,
like example,
if value<10:
else value>20:
Yes, there is!
Use a ColorBox to display colors. And use color constants to define the colors in your case structure…
2 条消息(共 6 条)
3,185 次查看
Thanks again sir for your help just the thing i was looking for.
0 项奖励
3 条消息(共 6 条)
3,173 次查看
But there a problem i need to pass 3 arguments in just 1 if else loop how could it be done.
0 项奖励
4 条消息(共 6 条)
3,162 次查看
解答
Hi Larry,
the case structure also can handle numeric values at its selector input, please read the help for that structure!
(Warning: this works best with integer data, float values might produce unexpected results.)
Additionally a case structure also supports more than just 2 cases: again read the help…
Or you use some array functions like in this simple example:
5 条消息(共 6 条)
3,157 次查看
Thank's sir that array method was much simpler for me to work, thank you.
0 项奖励
6 条消息(共 6 条)
3,144 次查看
