02-19-2014 06:35 AM - edited 02-19-2014 06:45 AM
I have the following problem.
I have a PC and a Laptop, both with the same Installation and Setup.
On the Laptop the visualization of a cluster differs to the PC. It is bigger and not everthing is visible (scroll bar for example).
Also the lines are not at the same level.
Has abnybody a idea why thats so?
Take a look at the pictures attached.
Thx.
02-19-2014 07:19 AM
Hmm, a different screen resolution and font anti-aliasing/smoothing?! The difference is not LabVIEW origin, I guess.
Cheers,
02-19-2014 08:09 AM
but the resolution of booth screens is the same.
02-19-2014 08:27 AM - edited 02-19-2014 08:27 AM
Dear stefkum,
it is hard to believe that the resolution of your laptop monitor is equal to that of the monitor of your destop PC, exactly. I believe you checked correctly, and you are the lucky one possesing such hardware combination (it is meant to be a kind admiration). By resolution I mean the number of vertical pixels times the number of horisontal pixels.
The ansicht_pc.png misses antialiasing of fonts, but that would not explain the scaling change.
The fonts in the two screenshots differ as well. Not only in the font-shape/family seems different, but their sizes, too. Check the fonts in the arrays on both systems, please.
Cheers,
02-19-2014 08:34 AM
The latter computer has Large font setting in display properties.
/Y
02-19-2014 08:39 AM
thanks, thats the solution!!
