Cluster to listbox
I'm learning to work with LabView and I need some advice.
I'm trying to implement a VI where I can store some data in a list. My data is a mix of integer, string and boolean.
Is there a way to store clusters in a listbox?
Or any other advice how can I accomplish it?
Thank you
Message 1 of 12
(5,730 Views)
Fairly easy to go from an array of cluster to a 2D array of strings
"Should be" isn't "Is" -Jay
Message 2 of 12
(5,707 Views)
Thank you
You can store data in a cluster.
What is the intent of using a listbox?
Message 3 of 12
(5,706 Views)
I need to display saved data. I push the button and my data are added to a table. There could be unlimited number of rows. So shift register isn't enough
Message 4 of 12
(5,700 Views)
Unlimited? Do you mean "N" number of rows?
Can you show how your saved data looks like? Jeff has already provided the answer as far cluster to Table in concerned.
Message 5 of 12
(5,696 Views)
I need it to look like that. Any ideas how to do it? I have tried for like 3 hours to do it.
Message 6 of 12
(5,691 Views)
Looks like an array of clusters.
Message 7 of 12
(5,672 Views)
yes, agree. but could you please tell me how to make it dynamic so it grows when I add new elements? And I couldn't find how to make a slider to scroll it.
Message 8 of 12
(5,668 Views)
Then attach a simple VI containing the control instead of a picture.
Message 9 of 12
(5,667 Views)
Its an array of cluster not a Table. Just add elements to the cluster Horizontally and set the Auto sizing to "Size to fit". Pull an empty array from the FP control palette, grab the cluster and drag it to the array. Go to Visible item of the array and un-select the Index option and enable the Vertical scrollbar. You are good to go.
Message 10 of 12
(5,665 Views)
