Cluster,arryas & type help
"the type of the source is 1-d array of cluster of 2 elements. the type of sink is cluster of 3 elements"
trying to plot a histogram graph and getting this error, how do correct this?
Message 1 of 9
(3,735 Views)
Hi dhanna,
you solve such problems by wiring the correct datatype!
Did you expect any other answer without providing atleast a screenshot of your block diagram?
Message 2 of 9
(3,727 Views)
yes screenshots shall be provided in a bit,just a bit busy atm, thanks for the quick reply
Message 3 of 9
(3,720 Views)
i want histogram 2 to replace histogram
Message 4 of 9
(3,701 Views)
Hi dhanna,
you should read the context help more carefully!
One of them is a "XY graph", while the other is a "Waveform graph".
Do you spot the difference now?
Why do you want to replace a XY graph by a waveform graph? What's the reason for this?
Message 5 of 9
(3,697 Views)
my situation is im testing an 8 channel board, but when i run histogram analysis all 8 plots end up on histogram as opposed the 1 i ty to choose (plot legend proving a bothersome), so used a created histogram (histogram 2) which had corrected plot legend etc.
Message 6 of 9
(3,684 Views)
Hi dhanna,
this sounds like some kind of misunderstanding…
When you make plots visible in the plot legend of a graph this DOES NOT change anything on the underlying data. It just sets the visible property of the plots!
When you want to analyse just one plot of your 8 available you need to choose it's data for analysis: most often you want to index some array subdata (like rows or columns). Use array functions to do so, IndexArray might be the first to try…
Message 7 of 9
(3,678 Views)
thanks very much,problem sorted. kudos will be given!
lastly how to get the plot legend & graph palette into the colour background? ive just made them white but want them to blend to this background (ie gridlines etc.)
Message 8 of 9
(3,666 Views)
Accepted by dhanna
Hi dhanna,
you should not paint them white, when you want to have them transparent!
You will find a transparent "color" in the color selector dialog in the upper right corner, represented by a "T". And most often indicators from classic palette are easier to customize…
Message 9 of 9
(3,661 Views)
