Closing windows command line using libraries
I tried to run the command as you said, but it returns this error mesage
Maybe I made a mistake writting the command you said, what do you think?
Message 11 of 20
(3,839 Views)
Yes, there is a mistake.
Why did you write the bolded stuff: taskkill /FI Símbolo del sistema eq cmd/c bla bla bla ?
You should write exactly as I have showed in the prior post. with "*" and make sure after taskkill there is a space in between taskkill and /F
I think you should write exactly the following: taskkill /FI "windowtitle eq Símbolo*" /F
Message 12 of 20
(3,836 Views)
I wrote it like that because I have undertood the message like this: taskkill\FI "(title of the window I want to close) eq (my command)" \F.
So then I have to write the code as taskkill /FI "windowtittle eq (tittle of the window I want to kill)*" /F.
I tried it writting what you said but the error remains.
Message 13 of 20
(3,820 Views)
https://technet.microsoft.com/en-us/library/bb491009.aspx
=== Engineer Ambiguously ===
Message 14 of 20
(3,816 Views)
Accepted by kibkib
Try with this: taskkill /im cmd.exe
Probably there is an issue with accents as you have your computer in spanish.
Message 15 of 20
(3,785 Views)
Okay, so you are saying to refer to the command window as an image, interesting I will try it.
Message 16 of 20
(3,769 Views)
Taskkill: Ends one or more tasks or processes. Processes can be killed by process ID or image name.
That is why I set the command window title in my example
Anyway the part I want you to see is I set the window title of the Iperf window with the "title Client" line in the batch file. This is important as you will see below.
To kill the running Iperf I use the taskkill command, notice that taskkill need the window title of the task you are killing.tkill.png
That says taskkill /FI "windowtitle eq Client*"
The only caveat I have ran into is taskkill can not kill a task that is ran as Administrator, seemingly even if my executable is ran as Administrator. I am guessing even if the LabVIEW executable is ran as Administrator, the systemexec is still running at lower privileges? So if someone has messed with Windows UAC (like I found on several machines on our lab) and set console windows to always run as Administrator, taskkill will fail.
Message 17 of 20
(3,757 Views)
 taskkill /im cmd.exe is working, but it closes the cmd window instantaneously. And as I explained before I need to close the window moreless in 10 seconds. It is posible to do what I want using timers or something like that?
Message 18 of 20
(3,741 Views)
Accepted by kibkib
Delay your calling of the SysExec that runs taskkill.
The simplest way to do this would be to use a Wait (ms) node with a constant and a Flat Sequence structure passing through an error wire or similar.
In 2017, there's a VIM called (I think) Delay Data Flow that does the same thing.
If you need other things to happen during that 10s, you can consider better structuring your code to allow a delay then the kill command. A State Machine might help you there, as could a Producer/Consumer design.
GCentral
Message 19 of 20
(3,738 Views)
I used the VIM you mentioned and it works, im able to delay the clossing the time I want.
The name of the VIM is stall data flow
thanks for your help! My programm now runs automatically from the start to the end!
Message 20 of 20
(3,731 Views)
