Close one vi and open another
Hi
Is it possible to open another vi when I click a button and close the current vi.
thanks
Message 1 of 10
(4,599 Views)
Sure, all you have to do is:
  1. From the current VI, open a VI reference to the new VI
  2. Run it using the Run VI method (be sure to wire a "false" to the Wait until Done input)
  3. Open its front panel using the Front Panel: Open method
  4. Close the current VI's reference to the new VI
  5. Close the current VI's front panel using the Front Panel:Close method
  6. Stop the current VI
Be sure to do steps 2 and 3 in the order shown here - it looks better.
Mike...
Message Edited by mikeporter on 07-01-2007 08:25 AM
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(4,594 Views)
Hi sujeep,
what about using 2 subvis connected by good dataflow (error cluster?!) to ensure sequential processing?
Message 3 of 10
(4,568 Views)
Hi Mr. Mike
Cn u explain me about the reference to vi. Where do I kind that.
Also can I get the values that I enter in the first vi to the second vi other than to store in a file and then retrive in the second vi.
thanks in advance.
Message 4 of 10
(4,551 Views)
Hi sujeep,
again: why not use subvis with proper dataflow?
See this codesnippet:
the first vi is getting some data, after closing the vi the next vi is started and gets the data from the first one...
Message Edited by GerdW on 07-02-2007 02:15 PM
Message 5 of 10
(4,547 Views)
Thanks a lot  I got the concept.
Message 6 of 10
(4,541 Views)
Here, try this. Enter the path to the VI you want to launch and run the program. When you press the button, the VI you specified will be launched and the program will be closed.
Mike...
Message Edited by mikeporter on 07-02-2007 07:43 PM
LabVIEW Champion
Message 7 of 10
(4,512 Views)
Hello Mr. Mike
As my labview version is 8, I am not able to see the vi attached by u. So cn u explain me.
Message 8 of 10
(4,493 Views)
Here.
Mike...
LabVIEW Champion
Message 9 of 10
(4,483 Views)
Thanks Mike - excellent instructions.
Thought I'd include a screenshot of your code in my application.
(Ignore the case structure: it was purely for timing purposes)
Message 10 of 10
(4,129 Views)
