Clone?
I am looking over my co-workers code, and a lot of the vi are opened as a clone.  I have the following questions.
1. What is the purpose of making a vi into a clone?
2. How do you make something into a clone?
3. How do you get something out of clone?
Yik
(5,138 Views)
Yik
1) So the code can be in more than one place at the same time.
2) A re-entrant VI opened with the "08" switch to load a new instance and creat the clone.
3) Depends on the clone.
Ben
(5,136 Views)
Look up "Reentrant execution"
Omar
(5,128 Views)
Accepted by topic author jyang72211
Clones allow debugging and probing of reentrant VIs, something that was not possible many version ago.
A clone represents a local instance of a reentrant subVI and is always in run mode. Showing a clone makes mostly sense during debugging. To edit the subVI, you need to switch to edit mode and changes will then apply to all clones.
You don't "make a VI into a clone", this is just a temporary state while debugging reentrant VIs.
A detailed description can be found in the following document:
Why Does my SubVI Have the Title subvi.v:i#(clone)?
(5,121 Views)
Thanks.  I knew what a re-entrant vi is, but I never connected the dot between that and clone.
Yik
(5,069 Views)
