Clock Routing example "Destination Terminal" = "BoardClk"?
Several of the clock routing examples have a Destination Terminal of "BoardClk". I can't find any documentation on what this is or where it goes. I've attached one of the examples, "Route Clock.vi", which can also be found under Example Finder > Hardware Input and Output > Timing and Synchronization > Signal-based > Route Clock.vi.
The specific hardware I'm experimenting with is the PXIe-6674T. I've looked in the manuals for the PXIe-6674T and the PXIe-1082 chassis. Google has no results.
(3,410 Views)
Accepted by jchedstrom
The NI-Sync examples cover a number of modules. Therefore, some of the terminals listed in the examples may not be available on the PXIe-6674T.
BoardClk is only a valid terminal on the PXI-668x modules. This terminal is used internally by the Multi-device PXI_Clk10 Disciplining software. With the PXI-6683(H), this terminal can be used for single-device PXI_Clk10 disciplining as well.
-Tyler
(3,383 Views)
Just looked at the PXI-6683(H) datasheet. It doesn't say anything about "BoardClk", but I've been warned that inconsistencies between hardware/software terminology exist.
Thank you for the quick response and the good explanation.
(3,369 Views)
