Clock / Project help
Hello everyone,
Is there a way to create a LINEAR number that increases as long as the loop is runnning? Simular to "LOOP ITTENERATIONS" in while loop. Im trying to create a simple clock type VI that will use that number.
Im basicly trying to make a CLOCK with simple math functions and a loop, but it keeps failing. The math looks good but the loop simply resets instead of adding an additional number to my X. What am i doing wrong?
Ive figured out how to make the output into minutes or seconds, and I think I can get a stucture to work with true or false number being LARGER THAN 60 and then minusing 60 from the X to reset the seconds.
Some one please help, ive been at this for like over 5 hours...
(4,804 Views)
Have you ever heard of "Clock Arithmetic" (or Clock Mathematics)?  If not, type this phrase into Google and think about what you read.  Then think how to apply this (check out the Numeric functions).
(4,778 Views)
Accepted by topic author unknown1
You just need to use Quotient & Remainder to gets your minutes and seconds.
(4,775 Views)
and I think all you need is this:
You can set the formatting of numeric indicators to a lot of different formats…
(4,752 Views)
Thank you, this works good
The seconds is the remainder, and I use the quotient for the calculaton of the minutes, and its quotient for hours. Works wonderfuly.
My math level is quite low, so i dont understand time calulations beyond the simple math, im not even sure how quotient and remainder works, its magic.
Thanks a bunch
(4,719 Views)
Thanks a bunch
Basically it's a divide, where you'll get the integer part (a normal divide rounded down) and the remainder (opt. it can be calculated as the fractional part times the divisor).
E.g. 4%3 = 1.33 rounded down = 1, 3*1 is however 3, so the remainder is 1. Q=1, R=1
It can also be described as "You can remove 3 from 4 1 time(s), and that'll leave you with 1 rest/remainder/unused"
11%4 "You can remove 4 from 11 2 time(s), and that'll leave you with 3 rest"
11%4 = 2,75 = Q 2, R (11-2*4 alt. 0,75*4) 3 = Q 2, R 3
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,686 Views)
