Clearing a string
In LabVIEW, I want to input a bar code into a field, record the data and then clear it after one iteration. I would also like to make that field the key focus and ready for the next UUT.
(2,938 Views)
After recording it, wire an empty string constant (on the string palette) to a property node of the control (value property) or to a local variable. Key focus is also a property node or attribute node in LabVIEW 5.
(2,938 Views)
Thanks, that worked!
(2,938 Views)
