Clear arrays into a non stop while loop
I appreciate all your advices. I really new in labview. It looks like nice and quick to make code but I feel a little lost to make I correct software structure as I can do with C or other writing languages. Pratice will help me for sure.
Message 11 of 16
(2,170 Views)
Oh. You mean you actually need to clear the Feedback Node. I see.
Give me a moment... I'm going to put together a more complete answer for you.
Message 12 of 16
(2,170 Views)
Accepted by Paulo_Medeiros
OK. I have attached 3 files to this e-mail. Save them all in the same subdirectory. Then open the VI and take a look. I've included tons of comments to explain everything. I hope this helps. (The files are saved in LV 2013... I hope that's early enough for you... it's the same version as the VI you uploaded.)
I hope some of the others on the forums can help you from here... I'm going to be only sporadically available from tomorrow until after NIWeek. Good luck.
Message 13 of 16
(2,167 Views)
Note to other LV users: The code I put in my previous post is good code showing a basic state machine and controller, but obviously, there are many advancements, improvements, and alternate implementations. I was trying to present as much good architecture as I could in one lesson without turning it into an entire training course. 🙂
Message 14 of 16
(2,163 Views)
The whole training course is available from the project Templates..
AQ likely contributed to most of themSmiley Wink
"Should be" isn't "Is" -Jay
Message 15 of 16
(2,158 Views)
This code is really so wonderfull. Thank you. Issue solved 😉
Message 16 of 16
(2,146 Views)
