Class Hierarchy window scrolling bug
Hi KuGr,
I have LabVIEW 2012 SP1 and installed the TSVN Toolkit version 1.7.1.64 (latest), but I still can't see the refreshing behaviour... By the way, where do you access the settings of the TSVN Toolkit?
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 11 of 14
(661 Views)
Well spotted - this seems to be the cause of my problems also.  I only see this behaviour on the couple of machines where I've installed the VSI toolkit, and changing the VSI refresh also changes the Class Hierarchy refresh.  Do keep us updated with any further information.
Thanks.
Greg
Message 12 of 14
(649 Views)
REDS:
I am using VSI's TSVN Toolkit 1.8.0.0 version and the Settings is in the Tools menu of the project explorer.  That version seems to have been pulled from their website.  I expect it will show up again.  I have talked to VSI but their developer is out until January 6th.
Message 13 of 14
(625 Views)
Hi GregS,
I'm glad you already found a workaround, I would like to remind you that NI doesn't oficially supports third party add-ons, so I would recommend you to wait until Monday 6 to contact with SVI to help you keep working on this issue.
Daniel Cabezas
Applications Engineering
Message 14 of 14
(600 Views)
