Clarification re: For Loop within a For loop
I have an inner For Loop that collects data points using a machine, which iterates "Number of Points + 1" times and an outer loop that iterates 10 times to repeat the whole data collection 10 times (please see attached image for reference). Does this mean that the inner For Loop is what gets executed first before the outer For Loop?
(1,029 Views)
Accepted by topic author solarfacility_user
Yes. Any structure cannot continues until all components have finished. In this case, the inner loop. If you wrap it as a sub-vi, would you have the same question? 🙂
Qestit Systems
Certified-LabVIEW-Developer
(1,019 Views)
Hi user,
Please speak out loud "THINK DATAFLOW!" whenever you have a question about "what executes first, what comes next"…
(It really helps to get reminded on this very basic mantra of LabVIEW from time to time.)
(1,014 Views)
LabVIEW data flow can be summed up in two sentences:
  • A node will not execute until all inputs are satisfied.
  • A node will not produce an output until the node has executed completely.
If you apply this in the most literal sense that you can, you'll be able to solve 99% of your dataflow questions.
Edit:  Structures such as FOR loops, qualify as nodes.
Bill
CLD
(Mid-Level minion.)
(962 Views)
