Citadel behavior
i need to understand the behavior of Citadel database in order to archive some shared variables.
In fact in a VI i use "Get process List" and "Get Shared Variable List" to have a list of all Shared variables in the server and i put all these Shared Variables in a listbox.
I need to have the following: when i choose a Shared variable from the listbox, this variable should begin to be traced (or archived) in a database. How can i introduce the Citadel behavior in a VI ?
Would you help me please ?
Samer,
(3,000 Views)
I haven't worked with the 8.5 DSC version yet. In the old days with the tag engine, the logging was done automatically once you setup the configuration to do it.
Here is the 8.5 info. Sounds like it happens when you create the shared variable.
Configuring Data Logging
When you add logging to a shared variable, the DSC Module logs shared
variable data, including the shared variable value, timestamp, whether the
value is in an alarm state, and the quality of the value. The DSC Module
logs all data to the Citadel database. Complete the following steps to add
logging for the Tank Level [Gallons] shared variable.
1. Right-click the
Tank System Shared Variables.lvlib project library
and select
Edit Variables from the shortcut menu to open the
Multiple Variable Editor
window.
2. Double-click the
Logging:Enable cell for the Tank Level [Gallons]
shared variable and select
On from the drop-down list that appears.
Additional logging options appear as columns in the table.
3. Double-click the
Logging:Alarms and Events cell for the Tank Level
[Gallons] shared variable and select
appears. This option enables alarm and event logging for the shared
variable.
4. Double-click the
Logging:Data cell for the Tank Level [Gallons]
This option enables historical data logging for the shared variable.
5. Double-click and enter
0.1 in the Logging:Data cell for the Tank
Level [Gallons] shared variable. This value compresses the value to
one decimal point when the DSC Module logs the values of this shared
variable to the Citadel database.
6. Leave the
Logging:Deadband cell with the default value of 0.01.
This value specifies that the DSC Module log the shared variable value
only when the shared variable value differs from the previous shared
variable value by 1% of the shared variable engineering scale range,
which is 0–100 by default
(2,985 Views)
Thx,
I know these informations....but i need to install all this behaviour in a VI...i don't want to Edit Variables to do this...
In fact i want to program all this in the VI...so when i choose a "Shared Variable" using "Get Shared variable List" in a VI i will be able to have all the choices that you informed me.
Could u help me please ?
Samer,
(2,953 Views)
