Child vi cannot disappear when parent vi rolling up
Hello Carya,
Can i dynamically call a subpanel?
because i would like to call uncertain amount of control during run time
the reason i use vi as child window because i cannot dynamically call the control (the control must be created before running the program)
by using child window concept, not only i can create any amount of control on demnand, I also can move the control freely, which is what i need(because i may need to focus on certain test cell during presentation)
Message 11 of 26
(1,768 Views)
 also notice that in the last video i post, there is another abnormality
when i call the subvi and set it as child window, it front panel dissapear
i have to "dip" it in the parent window border to recover the front panel
how ever this will not happend if i hide the window title bar first
Message 12 of 26
(1,765 Views)
LabVIEW does not have child windows. Use a SubPanel.
Message 13 of 26
(1,758 Views)
Hello Carya,
what do you mean by this?
as far as i know, you can set vi window as child window of another another vi window using user32dll as shown in my last video
Message 14 of 26
(1,755 Views)
Message 15 of 26
(1,751 Views)
@coloredsound wrote:
Hello Carya,
LabVIEW is not mend to do stuff like that. You can do stuff like that, but you'd be swimming against the flow. It will not do you any good.
Have I mentioned already that SubPanels is what you want?
Message 16 of 26
(1,747 Views)
Hello Carya,
Thank you for the code, this seem to be working
is it possible that i dynamically create the subpanel, on demand?
because as far as i understand, the subpanel is also a type of control and control cannot be dynamically created
Message 17 of 26
(1,746 Views)
Hello Carya,
You are right, you can't dynamically create them.
However, if you must do it dynamically, you can create 1700 (I tested this with 1700 but that number is random) of them and show\hide\move them at will. 1700 will be your maximum but that might be enough. If not, maybe 3000? There should be very little overhead, subpanels are very efficient. It might very well be more efficient then 1700 sub VI's on top of a main VI.
BTW: XControls might also help, but I'm no fan.
Message 18 of 26
(1,741 Views)
Hello Carya,
thank you for your advice
Message 19 of 26
(1,736 Views)
Hello Carya,
Please accept an answer, or formulate your answer so you can accept it. Keep the forum clean.
Message 20 of 26
(1,732 Views)
